rs newb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138155
Printed Date: April 10, 2026 at 3:53 AM
Topic: rs newb
Posted By: edgecrusher72
Subject: rs newb
Date Posted: January 06, 2015 at 8:38 AM
Try not to laugh to hard at my inquiries. I have installed a bulldog rs82b in my wifes 05 honda pilot. This rs has a built in bypass module. It seems the transponder antenna loop is not turning off and cannot start with key. Bypass part is powered by constant + per bulldog instructions. Can I power this from ignition output from rs to fix this? Also I would like to interrupt ignition input to keyless module with a relay but have already use GWR for keysense to fix dome light issue. Can I use same GWR to trigger the relay? If so do I need to isolate these circuits with diodes? Which side do I put anode?
Posted By: howie ll
Date Posted: January 06, 2015 at 9:09 AM
First part, I have no knowledge of this system,BUT bypass may be constantly powered bit it should be TRIGGERED by GWR.
The last part, yes isolate with diodes, diode bands towards RS.
Date Posted: January 06, 2015 at 10:13 AM
Thanks howie for the help but this is a strange unit. It has the bypass built in however it is powered separately but must be triggered internally.
Posted By: tedmond
Date Posted: January 06, 2015 at 7:36 PM
9 pin Harness Yellow/Black to 4pin Orange bypass wire. Red to constant 12v.
no need to power the keysense. the domelight will shut off on its own
------------- Ted
Compustar Expert
