autopage rs-730 alarm system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138217
Printed Date: April 07, 2026 at 1:10 PM
Topic: autopage rs-730 alarm system
Posted By: motor1581
Subject: autopage rs-730 alarm system
Date Posted: January 11, 2015 at 9:42 AM
First, Thank you for any assistance I recieve reference this topic!
I purchased an Autopage RS-730 car alarm for my 2000, Toyota Camry.  Old, yes, but tired of it being broken into!  I havn't installed an alarm system since the 1990's, and how these have changed.  The instructions are less than adequate!  They included a seperate relay with four wires, not within the main brain, that is not covered in the instruction portion at all.  I'm also confused with the terminology depicted within the instructions. I have downloaded the wire schematics and color codes for this vehicle already prior to the install.  So, I have a general idea where to locate the wires for connection, but need a bit more of direction.  If I had $300, I would pay someone to install this, however, that's not the case.  If anyone has installed this system in a same / like make, model, I would greatly appreciate ALL of your input to help with the install.
The wire colors on the seperate relay are:  Red, White, Purple and Yellow.
If you have any input, whatsoever, it would be greatly appreciated!  Thank you!
Thank you for your help!
Posted By: auto enhancers
Date Posted: January 14, 2015 at 3:26 PM
I believe that is a starter kill relay.
