first time comando rs-560
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13823
Printed Date: May 15, 2026 at 6:57 AM
Topic: first time comando rs-560
Posted By: marco2003
Subject: first time comando rs-560
Date Posted: May 21, 2003 at 10:17 PM
HELP WITH
COMANDO RS-560
COULD SOME ONE GIVEME STEP BY STEP INSTRUCTIONS.
PLEASE .
Posted By: draasch
Date Posted: May 22, 2003 at 6:47 AM
we need to know the yr make and model
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: May 22, 2003 at 4:23 PM
chevy suburban 99
Posted By: draasch
Date Posted: May 22, 2003 at 7:35 PM
Make:   Chevrolet
Model: Suburban
Year:    1999
This Database Was Last Updated On:    10/7/02
Index #: 8243
Alarm
Constant 12 volts RED & RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light GRAY (-) AT HEADLIGHT SWITCH *
Trunk Pin Switch SAME AS DOME LIGHT
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock L BLUE DRIVER KICK #202
Power Unlock WHITE PANEL
* WHITE (-) Wire At Headlight Switch Or At Courtesy Lights Under The Dash Can Also Be Used For Domelight But Will Not Trigger Alarm If The Domelamp Override Switch Is On. #202- See Positive Pulse Doorlock Diagram.
Remote Start
Tach Signal WHITE AT IGNITION COIL #238
Ignition #2 WHITE IGNITION SW HARNESS(TRANSMISSION)#235
Ignition #3 ORANGE IGNITION SW HARNESS(HEAT/AC)
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety N/A
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost
WARNING!! This Vehicle Comes Standard With G.M.s New Passlock II System. Please Refer To Note #238 Before Attempting To Install A Remote Start. #238 - See G.M. Passlock II Diagram. #235 - See Powering Extra Ignitions Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
