2005 lexus es330 neutral shuts car off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138403
Printed Date: April 03, 2026 at 1:43 PM
Topic: 2005 lexus es330 neutral shuts car off
Posted By: deuceman02
Subject: 2005 lexus es330 neutral shuts car off
Date Posted: February 03, 2015 at 3:24 PM
Hey guys, i just installed a Avital4103 with pkall bypass and everything works perfectly except when the car is shifted into neutral it cuts the car off. This occurs when the car is remoted started or with the key. The shutdwown diagnostics shows however the remote starter was shutdown last and doesnt change when the car shuts off in the neutral position. Any suggestions would be appreciated. Thanks
REP
Posted By: tedmond
Date Posted: February 03, 2015 at 4:28 PM
the vehicle already has a problem. if it happens with the key, the vehicle wiring is faulty or you installed something incorrectly.
Ted
Compustar Expert
Posted By: banthonyb71
Date Posted: February 03, 2015 at 5:44 PM
did you tie into the neutral safety switch?
Posted By: howie ll
Date Posted: February 04, 2015 at 1:03 AM
Last post
WTH has neutral safety switch on R/S to do with the engine cutting out when transmission is placed in neutral, even on normal start?
Date Posted: February 04, 2015 at 7:59 AM
geez. I don't know. Maybe if op tapped into a vehicle neutral safety wire in the vehicle, that would explain why he his problems in neutral. Just a thought. If ur not free and just on here bashing. Why did you join a 12volt forum?
Posted By: tedmond
Date Posted: February 04, 2015 at 8:50 AM
This is what I meant by you not understanding basics in the other thread, before helping others out. Neutral safety circuit allows a car to start while it's NOT IN GEAR. Neutral safety does not cause a car to shut down. Think about it... if a vehicle is moving, would you want to accidentally shift into neutral, have the entire car shut off? Losing power steering, brake vaccum? Manufactures don't design the circuit this way. If you understood that, then the idea of connecting to a NSS circuit wouldn't have been pointed out.
OP mentioned it happens with the key, then the vehicle itself has an issue. No car should shut off while moving the shifter.
I joined the 12v to help others, just like my actual profession in med-It's about help not here to bash anyone.
Ted
Compustar Expert
