90 acura integra power mirrors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138987
Printed Date: March 31, 2026 at 10:45 PM
Topic: 90 acura integra power mirrors
Posted By: pitoaudiovisual
Subject: 90 acura integra power mirrors
Date Posted: May 18, 2015 at 5:55 PM
Does anyone have a diagram for powered mirrors for a 90 integra. I have the switch but the customer gave me a relay so that the mirrors when the car turns on and off will fold in and out. The relay has 5 wires if that helps just not sure what wire goes to what and I don't wanna burn anything out. Thank you in advance
------------- Confidence is the key to any project!!
Posted By: howie ll
Date Posted: May 19, 2015 at 2:50 AM
Do the mirrors shut off at end of travel?
Posted By: howie ll
Date Posted: May 19, 2015 at 2:53 AM
If not use a pair of DEI 528t timer relays as this diagram, colour coded.
DZF_ignition_controlled_mirror_fold.png------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
Date Posted: May 19, 2015 at 8:54 AM
OK the customer told me that the mirror only opens and closes when u press the button so u would have to hold the button until the mirror is out or in.
Posted By: howie ll
Date Posted: May 19, 2015 at 8:59 AM
Then the diagram I showed you removes the need for a button, completely automatic.
Test on a bench how long the mirrors take in each direction, add one second and adjust each 528t for that time.
Date Posted: May 19, 2015 at 11:47 AM
Its all factory I have a factory switch with the button on it and a factory relay with that is suppose to connect to the mirrors with no extra parts.I would buy extra parts but I'm not suppose to. Everything should be there just a matter of wiring it up
Posted By: howie ll
Date Posted: May 19, 2015 at 1:06 PM
Can't be done with just one relay, use ordinary Bosch type and the battery will drain when the car is standing still, also you'll burn out the mirrors if they don't have an auto-stop.
Hence the two timer relays. If you can't buy extra parts refuse the job.
