Remote start starts then shuts off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139077
Printed Date: May 16, 2026 at 1:50 AM
Topic: Remote start starts then shuts off
Posted By: malibuguy3100
Subject: Remote start starts then shuts off
Date Posted: June 12, 2015 at 11:59 AM
Hey guys! I just registered here because it looked like an awesome place for help! So I found out a couple weeks ago my 1999 Chevy Malibu had remote start. I ordered a remote, but it still wouldn't work. I took it apart and the internal jumper was set to off. I switched it on and now my car cranks, fires, then immediately cuts off. I don't think its the anti theft, because the module cuts the ignition completely off during starting. Do you guys have an ideas? I would extremely appreciate it! And I hope I'm posting this in the correct thread!! I'm new here!! :)
Posted By: kreg357
Date Posted: June 12, 2015 at 1:34 PM
Did you check for a bypass module? The car has the Passlock2 engine immobilizer system and the symptoms sound like an issue there. There are many possible bypass modules, including just relays and a resistor.
------------- Soldering is fun!
Date Posted: June 12, 2015 at 2:11 PM
I checked it, but come to find out there was another jumper inside the brain that had something to with the tachometer. I switched it and it still didn't work. So I looked at the tach wiring under the hood, and whoever installed it hooked the wire up to the wrong wire on the coils. I switched it to the white wire and it worked!!!! Yay!! Thank you so much for your time! I was starting to think it was actually the bypass module. Thank goodness it wasn't!
