Accessory Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13913
Printed Date: May 16, 2026 at 5:41 AM
Topic: Accessory Wire
Posted By: mosameer
Subject: Accessory Wire
Date Posted: May 23, 2003 at 10:03 PM
Hi all!
Im installing a Compustar 2WFM with a CM3000 Module onto a european car...Peugeot 306 Cabriolet...im having problems with finding which wire is the Accessory wire at the ignition switch. Does anyone know what sort of reading it shoudl show when presenting it with a voltmeter? Any advice would be great! Thanks
Posted By: Velocity Motors
Date Posted: May 23, 2003 at 10:38 PM
The ACC wire should read 11.5 volts and 14.4 volts with the key in the ACC and RUN positions. There may be 2 ACC wires on the car ( if so then you will need to power both of them up ).
