2014 civic si laser scanner
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139819
Printed Date: April 05, 2026 at 4:25 PM
Topic: 2014 civic si laser scanner
Posted By: straightshot7
Subject: 2014 civic si laser scanner
Date Posted: December 01, 2015 at 1:36 PM
I'm wanting to install a red laser scanner strip for theft deterant and some bling, I'm wanting to tap it into the factory arm trigger wire, I will eventually have a viper alarm remote start installed but was hoping to be able to find the factory trigger to tap into does anybody know where it is located on my car? I see there is a security wire that runs to the back of my heads it where there is a light that flashes when car is locked, I was hoping to tap it below dash somewhere
Posted By: beegbie
Date Posted: December 04, 2015 at 7:42 PM
I think there's a reason no ones responded to this. The description of exactly what your trying to do here is vague. Laser scanner? Sounds really cool, I want one, what is it?
Date Posted: December 04, 2015 at 7:49 PM
A led light strip like this
https://m./itm/131064753947
Date Posted: December 04, 2015 at 7:53 PM
Well it didn't link it, it will scan back and forth while wired into security system when its armed
posted_image
Posted By: howie ll
Date Posted: December 05, 2015 at 3:47 AM
Wait until you get your Viper then the trigger wire on that scanner goes to the orange ground whilst armed (GWA) on the Viper.
Posted By: pentavolvo
Date Posted: December 05, 2015 at 3:33 PM
Or just have it trigger when ever ignition is off
Posted By: howie ll
Date Posted: December 05, 2015 at 3:41 PM
That's true, run the NEG (-) to any ignition wire, it will turn off when you turn on the ignition.
Date Posted: December 13, 2015 at 3:59 PM
Ok I'm trying to wire in a relay to make it switch on my scanner, I think I found the wire I need a pink wire in the kick panel, to trigger relay, it reads 0 while unlocked then reads 12volts while locked and factory armed, now this is a positve trigger right, how would I wire this to a relay, to power the scanner, I have a add a fuse to insert into a constant 12v right, then would I need a negative output to power strip or positive?
Posted By: howie ll
Date Posted: December 13, 2015 at 5:05 PM
Why bother with a relay when I've already given you a sure and simple answer.
Date Posted: December 15, 2015 at 2:14 AM
I appreciate the answer u Gave me but I do not want to have the scanner on all the time when car is off, i know that would work, just I would like to have it only come on when I lock the doors, arm the security
Posted By: beegbie
Date Posted: December 15, 2015 at 9:24 PM
Good answer/explanation straightshot. Having it on all the time doesn't sound like a bad idea though. Your intentions are good but I'm concerned about the pink wire your planning on tapping into. Do you know what it does? Where it goes? It may work though, just put your negative wire from the scanner to ground and the positive to this wire and see what happens. No relay necessary. I'd really like to know what it is before using it.
Date Posted: December 15, 2015 at 10:12 PM
Well I paid for a day subscription to Honda tech service site and looked at a lot of diagrams and schematics, tried to find certain wires, which I'm not the greatest at schematics, i'm still stumped, lol my car has the keyless smart system with smart lock, smart push button start. My system I found out has rf remote signal which the keyless access unit controls the function to the mciu which then powers the lock and unlock, there is no actual alarm arm wire on my car, it comes on with door locks, it works through a b can system. well I tried to check if the lock system was a negative trigger Or positive through lock wires, well I think my system has a pulse voltage instead of a constant ground while locked or constant 12v while locked cause on both unlock and lock it will read 0 on multimeter, then it will quickly show 12volt then ol, back to 0.0, so I'm assuming the computer just pulses the voltage to lock.and unlock, I need a constant ground or voltage to open relay to power on light while locked
Date Posted: December 16, 2015 at 1:13 AM
Is there such thing as a pulse 12volt relay or module that will open up and cloaw wirh a 12v pulse and stay open until it receives another pulse? That way I could still wire into my door lock wire then be able to open up a constant 12v to power light while locked
Date Posted: December 16, 2015 at 2:32 AM
Never mind I found what I need, I think, looks like it will work fine for what I'm trying to accomplish, this is a dei 611t latching relay module, with pulse input to open and close circuit
https://m./itm/DEI-611T-12-VOLT-12V-ACTIVE-LATCHING-SWITCH-RELAY-WITH-PROGRAMMABLE-TIMER-/140333447156?_trkparms=aid%253D222007%2526algo%253DSIC.MBE%2526ao%253D1%2526asc%253D20150519202348%2526meid%253D314712ecdc3a4a2ba30d3994855ac589%2526pid%253D100408%2526rk%253D3%2526rkt%253D4%2526mehot%253Dpp%2526sd%253D151769936306&_trksid=p2056116.c100408.m2460
