omega rs360edp 2007 honda pilot
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139993
Printed Date: April 07, 2026 at 12:48 AM
Topic: omega rs360edp 2007 honda pilot
Posted By: bat9905
Subject: omega rs360edp 2007 honda pilot
Date Posted: December 22, 2015 at 1:28 AM
Currently working on a 2007 honda pilot . When i remote start the vehicle the neither the aftermarket remote or the oem remote will lock or unlock door. I have the rs door lock outputs wired to to keyless entry module on passenger side behind fuse box . any ideas as far as pulsing other wires to make this work would be greatly appreciated
bat9905
Posted By: kreg357
Date Posted: December 22, 2015 at 5:39 AM
The Factory remotes definitely won't work while the engine is running ( remote started ).  I recently did a 2005 Pilot ( same
GEN as yours ) and ran the R/S's lock and unlock wires over to the PKP.   That worked fine but that was only because the
2005 Pilot's still have the passenger door key cylinder.  Your 2007 Pilot does not have the passenger door key cylinder.
Think you will have to make the lock connections inside the drivers door ( or use an XK02 with the HODL firmware ).
The driver door lock switch lock is BLACK/ white (-) at the power window master switch, lt. blue 20 pin plug, pin 8.
The driver door lock switch unlock is GREEN/ red (-) at the power window master switch, lt. blue 20 pin plug, pin 18.
Posted By: bat9905
Date Posted: December 23, 2015 at 12:55 AM
Ok thanks I'll try that
bat9905
