install XL202 with 5x10, smartstart & PKE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140393
Printed Date: April 06, 2026 at 4:40 AM
Topic: install XL202 with 5x10, smartstart & PKE
Posted By: aykfc
Subject: install XL202 with 5x10, smartstart & PKE
Date Posted: December 25, 2015 at 3:33 PM
So I have a 5x10 I installed and it's working great. I installed a viper smartstart as well and that's working. I tried to install a 2102T PKE passive keyless entry. After much work, I was told you have to connect an antenna to it and then the antenna transmits the info to the 5x10. So I got a 6711t and I already have a 7752v remote. How do I connect the xl 202 now to the system? Do I connect the antenna to the xl202, then cut into the smartstart harness? Also, I ended up with two 6711t antenna. One of the antenna have the green 6 pin cable. The other has the 4 pin and two 2 pin cables. Do I need the xl202 with either one?
Also, if I have to bypass the PKE for the time being I can, but does anyone know if it's even possible to wire all this up? If so, how I can go about it. Thanks! I am trying to finish this today if possible.
Posted By: aykfc
Date Posted: December 25, 2015 at 3:34 PM
Also, if it matters, I have a 2013 Nissan juke SV Push to Start.
Posted By: ak609
Date Posted: December 25, 2015 at 5:30 PM
the xl202 is not needed for 4x10 or 5x10 units those are for dball only. what you need is the d2d y cable to install both devices to your 5x10 system. use type 4 on page 13.
https://directechs.blob.core.windows.net/documents/n2102t_pke_2012-07_vm20120710_print.pdf
Posted By: aykfc
Date Posted: December 28, 2015 at 3:21 PM
Thank you very much. I contacted directed and did the chat. They told me I needed the xl202. I got my antenna and remote paired last night without it. Only put off the project a month because of the wrong information. Ugh. I will be setting up the PKE soon. Can I just cut a d2d cable and tap into the wires from the smartstart d2d cable or do I need a d2d y cable.
Posted By: ak609
Date Posted: December 29, 2015 at 12:35 AM
i am assuming thay you could cut and splice into it not 100% sure though be a dei question. we are still old school and use a 5806 with dball lol
