2015 F150 Dash Cam
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140556
Printed Date: April 05, 2026 at 3:53 AM
Topic: 2015 F150 Dash Cam
Posted By: tom6224
Subject: 2015 F150 Dash Cam
Date Posted: January 02, 2016 at 8:44 AM
Happy New Year. First Post for me.
Looking to install a BlackVue Dash Cam in my 2015 Ford F150 STX.
Needs to be hard wired to fuse panel.
I need One fuse which is constant hot (Emergency Lamps/Cab Light)
And one fuse hot only when car is on (Cigar jack/Audio)
Any help would be appreciated.
Posted By: chev104275
Date Posted: January 02, 2016 at 11:06 AM
12volts
GREEN/ red (50A)
BCM in passenger kick, 22 pin plug (G), pin 22
Ignition WHITE/ orange + ignition switch, black 7 pin plug, pin 1
------------- If i Can't Install it I Don't need it Joe
Posted By: tom6224
Date Posted: January 02, 2016 at 1:37 PM
I most certainly appreciate your quick reply.
The information you provided however might as well be written in a foreign language. Is it possible to clarify a bit?
Thank you, thank you, thank you.
Tom.
Posted By: smokeman1
Date Posted: January 02, 2016 at 3:13 PM
He is telling you to the RED / Green wire at the he BCM(Body Control Module) is always "Hot". In passenger kick panel.
The WHITE/ orange is hot when vehicle is running. At ignition switch.
As always, test and verify with a DMM. (Digital MultiMeter)
------------- When all else fails, Read the Instructions
Posted By: tom6224
Date Posted: January 03, 2016 at 8:20 AM
Thanks, you guys are great! The instant feedback is greatly appreciated.
Now don't be mad at the newbie, but I fat fingered my post. I have a 2014 F 150 not a 2015. Pleeeeeeease don't be mad, but I'm looking for contact hot in the kick panel, and accessory hot in the kick panel. Thank you again!
Tom.
Date Posted: January 03, 2016 at 8:59 AM
12 VOLT CONSTANT RED (+) and BLUE/RED (+) @ BCM, BLACK 32-PIN PLUG (D) Pins 6 and 1
ACCESSORY /HEATER BLOWER 1 PURPLE / GREEN (+) @ IGNITION SWITCH HARNESS, BLACK 7-PIN PLUG, PIN 6
As far as finding them in the kick that's going to require some hunting with a dmm
Posted By: howie ll
Date Posted: January 03, 2016 at 12:07 PM
Or get to ignition wires with a DMM.
Even easier, dome light go to power and constant ground, will probably shut down 10 minutes after doors locked.
Test any of the above with a DMM.
Do not assume.
