Cant get my viper out of manual mode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140558
Printed Date: April 04, 2026 at 3:53 PM
Topic: Cant get my viper out of manual mode
Posted By: moodykelly71
Subject: Cant get my viper out of manual mode
Date Posted: January 02, 2016 at 7:57 PM
hey guys I have a viper 4204 and I installed it in my 2004 f150.i was having troubles getting it to work. so I went through and reprogramed it and now I have found that it wont come out of manual transmission mode. has anyone had this kind of issue before? iam at my wits end with this thing.
Posted By: triniforever
Date Posted: January 02, 2016 at 8:12 PM
Did you use the bitwriter ? This happened to me once and using the programming button with the remote to access the menu didnt work, i used the bitwriter and it solved the issue .
------------- triniforever
Date Posted: January 02, 2016 at 9:28 PM
no this is my first install and on my own vehicle so i dont have the bitwriter. thank you for your advice i will be taking the module to a local installer and seeing if they will program it.
Posted By: howie ll
Date Posted: January 03, 2016 at 6:44 AM
Do you have door trigger connected? To make sure you can program, ground the green door trigger connector during programming.
I must admit the programming instructions are confusing the first few times.
The other fact is that programming might have been locked, then you WILL need a Bitwriter.
Date Posted: January 03, 2016 at 3:17 PM
Yes I had the door trigger connected talked to my local installer today and he said they have run into this a few times and have the bitwriter. He will program it for me on Tuesday so I'll let you know how it goes
