Parking lights blink with remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140589
Printed Date: April 03, 2026 at 1:43 PM
Topic: Parking lights blink with remote start
Posted By: jass4752
Subject: Parking lights blink with remote start
Date Posted: January 06, 2016 at 4:59 PM
Hello
I have installed compustar CS800-s one way remote starter in my Honda CRV 2003 automatic.
the starter unit and CRV has 2 wires for parking lights. positive and negative.
i connected the positive parking light wire from the unit to CRV's positive parking light wire.
Now whenever i remote start my car, the headlights blink but does not stay solid.
how do i make these lights solid with remote start.
Do i have to add a relay ?
or connect it via negative parking light wire with relay?
are there any additional wires that i have to connect from the starter unit to CRV?
Thank you
Jass
Posted By: kreg357
Date Posted: January 06, 2016 at 8:04 PM
Never heard of that before. Are you sure you have the right wire? The CS800-s does not have a programming option for a blinking Parking Light output.
While it's slightly difficult to get to, I always use the (-) Parking Light wire at the factory alarm plug. I's a Green 22 pin plug just above the DKP trim piece. The (-) Parking Light wire is Blue at Pin 9. You can also get the (-) Horn signal there, Orange wire at Pin 6. ------------- Soldering is fun!
Posted By: bs1d3
Date Posted: January 07, 2016 at 2:34 PM
I'm seeing positive parking lights as being RED / yellow, there is a note however saying "Can also find a RED / Black in the connector above Kick Panel NOTE: " Dealer only to : ( to program another key "
Posted By: jass4752
Date Posted: January 08, 2016 at 3:30 PM
Hello
Yeah i did connect the orange horn Wire. everything is working fine except the parking lights.
So if i connect the Negative parking light wire, do i need a relay?
if i do, that's how i wire it? as in the picture below?
and where do i attach the fuse. at #1 or #2? or it does not matter. and how many amp fuse do i need?
and do i need to ground this connection?
and can i connect +12V constant to any 12v+ constant wire nearby? there is one @ harness in the driver's kick panel. 1 should be in the green harness as well.
Posted By: jass4752
Date Posted: January 08, 2016 at 3:35 PM
yeah i read it somewhere too, there one + parking light wire at the fusebox and one at the drivers kick panel harness (which is the one i connected). this connection is not working for me. lol
Posted By: mscguy
Date Posted: January 08, 2016 at 4:05 PM
Do not connect a relay wired like you have shown. That will cause problems, and possible melt something.
Posted By: mscguy
Date Posted: January 08, 2016 at 4:09 PM
You should just be able to connect your CM800 grn/white (-) parking light to the Blue (-) parking light in that green connector.
Check with a meter first though to make sure its right.
Posted By: mscguy
Date Posted: January 08, 2016 at 4:12 PM
Can't edit :(
I mean Grn/wht in CN2 harness. Connect negative to negative.
Posted By: kreg357
Date Posted: January 08, 2016 at 4:38 PM
As mscguy says. The CS800-s has two Parking Light Outputs. Both are GREEN / WHITE wires. The (+) Parking Light wire is in the CN1 connector and is a thick wire. The (-) Parking Light wire is in the CN2 connector and is thin. You should be able to just directly make than connection, CN2/1 GREEN / WHITE to the CRV's Green factory alarm plug, Blue wire at Pin 9, no relay required. The CN1/2 GREEN / WHITE (+) Parking Light output wire should be disconnected / not used.
Posted By: jass4752
Date Posted: January 23, 2016 at 5:17 PM
Remote starter unit is working fine now after connecting the negative parking light wire instead of positive parking light wire.
Thank you everyone for your Support.
