Avital 4103LX on 1997 Pontiac Grand Am Se
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140655
Printed Date: May 02, 2026 at 12:21 PM
Topic: Avital 4103LX on 1997 Pontiac Grand Am Se
Posted By: jeffsrawr
Subject: Avital 4103LX on 1997 Pontiac Grand Am Se
Date Posted: January 14, 2016 at 1:39 PM
I have installed the 4103LX on my wifes 1997 Grand Am Se 4 cylinder. All wires connected where wiring diagrams have told me. The previous owner had passlock bypassed (im guessing resistor permanent method) as it takes plain cut keys. There hasnt been a single check engine or security light on the dash.
First thing i noticed is the instructions say let virtual tach try to start car 3 times. Virtual tach has never works since install. So I connected tach wire to the white wire on the ignition coil harness. After learning tach it starts. Than it wont start after first remote start. If i relearn tach, it starts once than not again. DE of course would not talk to me without a dealer ID number. Its 32 degrees and been getting down to 0 degrees but a remote start should work at low temperatures otherwise whats the use? When I check shutdown sequence on the remote start it gives me 3 blinks which indicates Low or No RPM (or low voltage if using virtual tach or voltage sense).
Any ideas? i can upload a video if that would help. door locks worked after relay, valet mode (leave car running without key) works.
Date Posted: January 14, 2016 at 2:46 PM
after calling many shops i got one to actually talk to me without money up front, seems its passlock issue and needs bypass for remote start. hope that fixes it ordered a PLJX
