2014 Nissan Juke PTS
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140674
Printed Date: May 05, 2026 at 7:53 PM
Topic: 2014 Nissan Juke PTS
Posted By: triniforever
Subject: 2014 Nissan Juke PTS
Date Posted: January 16, 2016 at 9:37 PM
Having a problem programming the ALCA on this car, took out battery from keyfob but then the ignition does not turn with the battery removed from from keyfob and held to the start button . Any one ever did one if these cars ? Any help would be appreciated
triniforever
Posted By: Mark Mizenko
Date Posted: January 16, 2016 at 11:21 PM
Take the remote apart, hold the top of the board against the button
Date Posted: January 16, 2016 at 11:31 PM
Thats exactly what im doing but as soon as i take the battery out from the remote and hold the board against the push start button absolutely nothing happens when i push the button and the key light starts flashing
triniforever
Posted By: beegbie
Date Posted: January 17, 2016 at 7:12 AM
We've seen the chip come not programmed from Nissan. Very rare but possible. Did you try your other key?
Date Posted: January 17, 2016 at 8:41 AM
I didnt think to try the other key but now that you mention it i will definitely give it a try ...thanks guys .
triniforever
Date Posted: January 19, 2016 at 1:29 PM
The problem was when i was putting back the PTS button somehow the transponder receiver plug came loose so it wasnt reading the transponder fixed it and all is well ALCA progeammed right up. Thanks for all your help!
triniforever
