DEI - what’s the differences in paging?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14072
Printed Date: April 03, 2026 at 7:20 AM
Topic: DEI - what’s the differences in paging?
Posted By: bluersx510
Subject: DEI - what’s the differences in paging?
Date Posted: May 27, 2003 at 7:48 PM
I am looking at the clifford RS3, Python 880XP, and the Viper 790XV.. what are the differeneces between all of these??
Posted By: securinu
Date Posted: May 27, 2003 at 7:54 PM
Date Posted: May 27, 2003 at 7:55 PM
so what are the differences between all of these?? I looked at the specs on the DEI website and they all seem to have simliar if not the same specs.. can anyone assist?
Posted By: Scott35
Date Posted: May 27, 2003 at 8:05 PM
They are all the same unit.
------------- Tacomacrew
Date Posted: May 28, 2003 at 12:50 AM
really?? none of them have farther ranges or any other small differences? what would u guys recommend based on what u guys have seen? or it really doesnt make a diff?
Posted By: bdl666
Date Posted: May 28, 2003 at 12:58 AM
Go with the cheaper one of the three being that they are all the same. Different brand name, different price and warranty, all the same DEI Crap.
Posted By: philaf
Date Posted: May 29, 2003 at 11:14 AM
i don't know about the others, but the rs3 only works with the lcd remote. if it ever goes bad, you can't just program a standard clifford four button - you have to order that lcd piece for $100. that kinda sucks.
Date Posted: May 29, 2003 at 11:43 AM
WOw, is that true?? that sux..
Posted By: philaf
Date Posted: May 29, 2003 at 11:48 AM
yeah, you might want to check that with the others as well - it's all DEI...
Date Posted: May 29, 2003 at 2:18 PM
Wait, so are u saying its like that for ALL of the resp[onder alarms or just clifford?
Posted By: soon2bealarmtec
Date Posted: May 29, 2003 at 4:02 PM
You asked if it liked that for all alarm system no it depends also but usually it some 2 way pager. -------------
Posted By: Scott35
Date Posted: May 29, 2003 at 4:26 PM
All 3 of the remote systems mentioned, python,Viper and the clifford use the same remote.
Posted By: djfearny2
Date Posted: May 29, 2003 at 6:44 PM
yea those remotes work on an fm based signal. the other two way from dei by hornet uses a am signal so it can be interupted by interference but the other remotes work good i have the viper 790 xv and its cool cause the paging is ontime meaning when i press unlock both the car and the remote beep twice at the same time or with in a second no matter how long away iam as long as i am in range which is far...
------------- Jon
Installer/Help Technician
---coral springs florida---
Posted By: philaf
Date Posted: June 01, 2003 at 1:44 AM
if all you need is paging, dei makes an add on pager piece... it's a real pager system that gives a better range. can't remember the part# but i'll check at work tomorrow. and what i meant was that if the clifford only worked with the one lcd remote, there is a good chance that the others you listed did as well... being that they are all made by dei.
Posted By: jkormond
Date Posted: June 01, 2003 at 1:59 AM
clifford is owned by dei .And yes the viper responder remote also costs $100 +- a few bucks.
Posted By: Scott35
Date Posted: June 01, 2003 at 9:16 AM
You can get the 2way remotes on ebay for $75.
