1998 Jeep Grand Cherokee, keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140935
Printed Date: April 02, 2026 at 11:20 PM
Topic: 1998 Jeep Grand Cherokee, keyless entry
Posted By: mattl0728
Subject: 1998 Jeep Grand Cherokee, keyless entry
Date Posted: February 28, 2016 at 8:19 PM
I have a 1998 Jeep Grand Cherokee Laredo. I lost the one and only remote for my keyless entry, so..
I ordered 2 Omega Proline REC43t Keyless entry systems. Installed one in my fathers 2000 Jeep cherokee sport with no problems. However, when i installed it on mine it wont work. After searching for a while online i found the 98 JGC has a different setup and requires a different wiring setup? Something about adding relays, or a DEI 455tw system? Can someone please help me figure out how to get my keyless entry working, and what is wrong?
Thank you very much!
Posted By: brownsfan1
Date Posted: February 28, 2016 at 8:41 PM
You need to 5wire each door motor wire or find a 455t and interface into the data bus system. Dei discontinued this piece cheap years ago. Some go on eBay for stupid money because it's a lot of work to run wire into each door and the tail gate. I remember doing these when new. I would run 2 wires into each door for motor and switch side and install 2 relays to run the whole thing doing a standard 5wire
Date Posted: February 28, 2016 at 10:02 PM
Thank you for the reply.
I searched and cannot find one of the 455tw. If its not too much to ask, will you please give me an instructional on how to do a 5wire?
I have never done one before.. I would appreciate it ,thank you!
Date Posted: February 28, 2016 at 10:04 PM
And also,
Will any other system other than the DEI 455tw work for my vehicle?
I was hoping to find a cheaper way of doing it because it is expensive to buy that system, not to mention hard to find.
Any other keyless entry, or alarm w/ keyless entry that will work on mine?
Posted By: i am an idiot
Date Posted: February 28, 2016 at 10:23 PM
You only need to run 3 wires into 1 door. You will have to solder those 3 wires to the contacts of the contacts of the rocker switch inside the control assembly. You will have to use 2 relays that duplicate what the switch does.
Date Posted: February 29, 2016 at 7:34 PM
I remember doing the Trailblazers this way when they came out. I never did the Grand Cherokees this way. I guess it could work if you are good with a soldering iron. And to the Original poster. There is no other module that I have ever seen or heard of other than the 455t that did the locks in this vehicle.
