astrostart rs623, 08 Tacoma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141770
Printed Date: May 15, 2026 at 10:13 PM
Topic: astrostart rs623, 08 Tacoma
Posted By: reendawg74
Subject: astrostart rs623, 08 Tacoma
Date Posted: September 21, 2016 at 1:26 PM
so I have a 08 Tacoma with an astrostart rs623 I turned the toggle switch to on and tried starting with the remote and only the instrument lights come on tried about three times and no luck so I put the key in the ignition to start and no instrument lights and wouldn't turn over the headlights don't even dim and the truck was running 15 min prior to this
checked all the fuses and relays and battery has full charge
Posted By: lurch228
Date Posted: September 21, 2016 at 3:57 PM
Sounds like maybe the antitheft is on try unlocking the alarm and then try to start it. If the Antitheft is set to PASSIVE ARMING’ it has a 1 minute from unlock to start. ACTIVE only enables when the lock is pressed.
PASSIVE ARMING’ TYPE ANTITHEFT
This type of antitheft system arms automatically when ignition key is turned from ‘RUN’ to ‘OFF’ and remains ‘OFF’ for one
minute. It can also be armed manually by sending a ‘Lock’ command (unless ignition key is in ‘RUN’ position).
DISARMING
Antitheft system is disarmed for one minute when you send an ‘Unlock’ command.
If ignition key is not turned to ‘RUN’ position within one minute, system automatically rearms, thus preventing an intruder
from starting your vehicle, even with ignition key. The indicator light (optional) blinks rapidly during rearming, and then
continuously when antitheft system is armed.
It can be connected so that horn sounds if an intruder tries to start your vehicle when antitheft is armed.
‘ACTIVE’ TYPE ANTITHEFT
This type of antitheft system is armed by sending a ‘Lock’ command (unless ignition key is in ‘RUN’ position) and is
disarmed by sending an ‘Unlock’ command. The indicator light (optional) blinks continuously when antitheft system is armed
(if the AstroStart security system is not armed) .
Date Posted: September 23, 2016 at 4:44 PM
nope didn't work, checked all the wiring and connections
------------- 08yotataco
Posted By: lurch228
Date Posted: September 23, 2016 at 7:56 PM
If no crank then the starter disable must be hooked up and on or the security immobilizer of the vehicle has triggered.
