Remote Start Acura MDX 08
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142282
Printed Date: May 15, 2026 at 12:37 PM
Topic: Remote Start Acura MDX 08
Posted By: obeynation
Subject: Remote Start Acura MDX 08
Date Posted: December 21, 2016 at 5:12 PM
Hey All I am trying to install a Viper 4806v in my MDX I am using DBall2 just need help with the wiring is this correct
also nu = not used
I didn't use most of the 24 pin because d2d right ? any help would be great thank you in advanced
Remote Start, 8-pin connector
1 RED / BLACK (+) 12VDC CONSTANT INPUT White @ ignition
2 PINK/BLACK (+) FLEX RELAY INPUT 87A key side NU
3 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT ACC 2 red @ ignition
4 RED (+) 12VDC CONSTANT INPUT for ignition 1 relay gnition
5 VIOLET (+) STARTER OUTPUT Yellow @ ignition
6 ORANGE (+) ACCESSORY OUTPUT Orange @ ignition
7 RED / WHITE (+) 12VDC CONSTANT INPUT for ignition 2 and flex relays White @ ignition
8 PINK (+) IGNITION 1 INPUT/OUTPUT pink@ ignition
H/1 RED (+)12VDC CONSTANT INPUT white@ ignition
H/2 BLACK (-) CHASSIS GROUND Ground
H/3 BROWN (-) 200mA HORN HONK OUTPUT orange @ steering Column
H/4 WHITE/ BROWN LIGHT FLASH ISOLATION WIRePIN 87a light flash relay NU
H/5 WHITE PIN 30 of LIGHT FLASH RELAY NU
H/6 ORANGE 500 mA GROUND WHEN ARMED OUTPUT NU
1 PNK/WHITE (-) 200mA Ignition 2/Flex OUTPUT nu
2 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOGGER OUTPUT were would I hook this too
3 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT nu
4 BLACK / YELLOW (-) 200mA DOME LIGHT OUTPUT nu
5 DARK BLUE (-) 200mA STATUS OUTPUT nu
6 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT nu
7 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT nu
8 ORANGE / BLACK (-) 200mA AUX 4 OUTPUT nu
9 GRAY (-) HOOD PIN INPUT (NC OR NO)nu
10 BLUE* FACTORY HORN INPUT (Use Jumper to set polarity) nu
11 WHITE/ BLUE ACTIVATION INPUT nu
12 VIOLET/WHITE** TACHOMETER INPUT nu
13 BLACK/ WHITE*** (-) NEUTRAL SAFETY /PARKING BRAKE INPUT nu
14 GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT nu
15 GREEN** (-) DOOR INPUT nu
16 EMPTY ------------------------------------
17 PINK (-) 200mA IGNITION 1 OUTPUT nu
18 VIOLET** (+) DOOR INPUT nu
19 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT nu
20 BROWN (+) BRAKE SHUTDOWN INPUT nu
21 VIOLET / YELLOW (-) 200mA STARTER OUTPUT nu
22 GRAY/BLACK (-) DIESEL WAIT TO START INPUT nu
23 ORANGE (-) 200mA ACCESSORY OUTPUT nu
24 GREEN / WHITE (-) 200mA FACTORY ALARM ARM OUTPUT nu
Posted By: dairyboy3
Date Posted: December 21, 2016 at 5:53 PM
what year is it?
Never mind it was in the title. I am blind.
Date Posted: December 21, 2016 at 6:05 PM
H/5 WHITE PIN 30 of LIGHT FLASH RELAY- This wire should be hooked up to the parking lights. You can use the -brown wire at the headlight switch or you can use the +Gray wire in the driver kick. Depending on which wire you use you can switch the polarity of the output on top of the brain with the fuse jumper.
13 BLACK/ WHITE*** (-) NEUTRAL SAFETY /PARKING BRAKE INPUT- You need to ground this wire or the remote start wont work.
Date Posted: December 21, 2016 at 6:18 PM
Thank You, also how do I wire the defroster wire as well as power tailgate
