rattler 300(dei) door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14276
Printed Date: April 06, 2026 at 9:09 PM
Topic: rattler 300(dei) door locks
Posted By: NARAKU
Subject: rattler 300(dei) door locks
Date Posted: June 01, 2003 at 7:09 AM
Hello everyone,
I'm installing this unit in a 89 Crown Victoria LTD but, i'm confused about the wiring cause this unit comes w/ 2 harnesses 1-12 wire(primary) , 1-6 wire for the doors. The 12 wire primary harness also has connections for the doors with zones 1,3 next to it. Now my Newbie dumb Question is am i supposed to hook up both of the harnessess together to get these zones that is described in the install manual. I'm glad i found this forum great info. Thanks u for any replies.
Posted By: NARAKU
Date Posted: June 02, 2003 at 5:40 PM
Whats up peeps,
      I fixed it all now and i'm armed. I figured out the wires and all and i got most of the info here in car database except for one thing, the car info says Door Trigger to be BLACK/ light blue when i found it to be Light GREEN/ YELLOW. I don't know if this is an error and i don't mean to implie that it is after all i think i'm the only one with a 89 Crown Vic 4dr. Maybe its used with a relay i don't know if someone can explain this please do. That wire is there in that big harness behind the Glove Compartment. The BLACK/ Light Blue wire i found to cut off the lights inside under dash and doors. Like i said i'm a newbie who didn't want to pay for installation but, wanted to learn something new plus i'm protecting head unit, 4-spkrs inside car, 2-10's, 2-amps in the trunk. thanks again .
