Newbie needs some help!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14281
Printed Date: April 06, 2026 at 11:03 PM
Topic: Newbie needs some help!
Posted By: Nestamarley
Subject: Newbie needs some help!
Date Posted: June 01, 2003 at 9:06 AM
  I have a 1988 Buick Century with power locks and trunk release. I have a Vampire 3-channel alarm system and I have no idea where to even start. I read the directions and they are somewhat detailed, but I thought some help from some seasoned pros like yourselves would be helpful.
"In this bright future you cant forget your past"
Posted By: draasch
Date Posted: June 01, 2003 at 9:29 AM
Make:   Buick
Model: Century
Year:    1984-93
This Database Was Last Updated On:    10/7/02
Index #: 6354
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) PIN SWITCH OR AT COURTESY LIGHT
Trunk Pin Switch BLACK/ ORANGE (-) SWITCH OR REAR BODY HARN.(WAGON ONLY)
Parking Lamp BROWN (+) HEADLIGHT SWITCH
Power Lock LIGHT BLUE DRIVER KICK PANEL # 202
Power Unlock BLACK DRIVER KICK PANEL # 202
#202- See Positive Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: soon2bealarmtec
Date Posted: June 01, 2003 at 9:31 AM
Tell us what you want to start with.
Start with the siren ground one wire and the other you connect to the alarm wire, whatever wire the manual tells you.
Its not really hard all you gotta know is where the wires are located on the car and know which  color wire does what on the alarm.
Date Posted: June 01, 2003 at 1:24 PM
O.k., I thank you for the wire colors, thats a big help. but the #202 diagram you are refering to is that the same as the "3 wire positive diagram" on this site.
