Hyundai Accent Door Locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14306
Printed Date: April 07, 2026 at 9:10 AM
Topic: Hyundai Accent Door Locks
Posted By: psharley
Subject: Hyundai Accent Door Locks
Date Posted: June 01, 2003 at 6:22 PM
I bought a 2003 Hyundai Accent for my daughter and a CS-2003DC series II alarn. I have everything working, but can not get the doors to lock or unlock or the parking lights to flash. Does anyone know how to connect the wiring to make the parking lights flash, or door locks work? Do I need to but accuactors? Thak you Pete
Posted By: Chris Luongo
Date Posted: June 01, 2003 at 6:30 PM
Parking lights is one of the several GREEN/ orange in the driver's kick panel.
Above the fuse box are a handful of relays; locate the two gray ones. Put your hand on the relays while you operate the locks back and forth----you'll feel that one relay does unlock; the other does lock.
You may trigger these relays by connecting your alarm's negative doorlock outputs, to terminal 86 of each relay.
Posted By: JWorm
Date Posted: June 01, 2003 at 9:36 PM
Vehicles with keyless entry use BLACK/ orange for lock and yellow for unlock. They are negative trigger and found at the ETACS module to the left of the steering column.
