Viper 4105V+ DBALL3. Remote start will not work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143547
Printed Date: May 13, 2026 at 9:29 AM
Topic: Viper 4105V+ DBALL3. Remote start will not work
Posted By: IMPORTDUDE
Subject: Viper 4105V+ DBALL3. Remote start will not work
Date Posted: September 17, 2017 at 11:24 PM
Hi, Im installing the viper V4105V remote start in my
2010 accord. With DBALL3.
For some reason it will not work(the remote start) when i click the buttons i get no response from the V4105V alarm module.
I have wired it according to this pdf from directed.
https://www.directechs.com/DocumentDownload.aspx?d=-29738&p=590&f=19133
On the Viper module, I have the heavy gauge relay harness( thick 12v/acc/starter/2nd ig), primary harness( ground, and light flash), and then the d2d connector.
I'm leading to believe i might need the brake shutdown input (+) , and the parking brake input(-) from the 5pin remote start harness to be installed.
Whats throwing me off is the directtech pdf says its not needed.
thanks
Posted By: howie ll
Date Posted: September 18, 2017 at 4:48 AM
Silly question, has the DB-ALL3 been flashed?
Have you tested power and grounds at the fuses?
Have you checked you have the right wiring at the immobiliser plug?
Did you get correct LED flash from the DB-ALL3 when you installed and programmed it?
Posted By: beegbie
Date Posted: September 18, 2017 at 5:47 AM
Ground the black/white wire on the 4105
