Help bulldog rs602e ( piece of crap)
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14378
Printed Date: April 08, 2026 at 2:38 PM
Topic: Help bulldog rs602e ( piece of crap)
Posted By: abel
Subject: Help bulldog rs602e ( piece of crap)
Date Posted: June 02, 2003 at 9:17 PM
I've installed a buldog rs602e, I tried all the inputs , pin switch , aux input , shock  sensor input , etc , but in all cases went I arm the alarm and open the door  it  takes like 1 minute to activated the siren or even more .
I couldn't figure out how  to  program this piece of crap , to avoid that delay ....
 I will appreciate any help
thanks in advance
abel
Posted By: bdl666
Date Posted: June 03, 2003 at 2:33 AM
   Sounds like you have a bad unit or that you have something connected in the wrong place. I have installed a few of these units and they work the way they are supposed to. They are cheap and the range on the remotes suck's, but they work . One of them has been on use for three years now with no problems. Oh and they don't have a delay.
            Call the company there is always a tech that can help you with the install. If the unit is bad they will exchanged.
