2010 MKZ, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143909
Printed Date: May 16, 2026 at 5:19 AM
Topic: 2010 MKZ, remote start
Posted By: big_bogus
Subject: 2010 MKZ, remote start
Date Posted: December 19, 2017 at 10:24 AM
Trying to install add on remote start. Only problem is I can't find the lock motor (gray/brown or blue/green wire ?? not sure which). I have the drivers side kick panel out and the bundle of wires accessible BUT I cannot find a blue/green and gray/brown doesn't test correct. Any hints or pictures would be great. Hate to take the door panel off, but need to get this done today as the weather is VERY nice for now.
Posted By: geepherder
Date Posted: December 19, 2017 at 12:50 PM
https://diagrams.marktoonen.nl/printlist.aspx?MakeID=28&ModelID=20027
The color may be different, but Bulldog has power lock as pin 17 of the SJB grey 26 pin plug (C).
This will hopefully keep you from having to run wire into the door. Otherwise:
https://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=177070
------------- My ex once told me I have a perfect face for radio.
Posted By: chev104275
Date Posted: December 19, 2017 at 4:48 PM
The wire listed above is the switch wire and won't work for what your trying to do
You want the
LOCK MOTOR WIRE GRAY/BROWN (5-WIRE TYPE) IN DRIVERS KICK PANEL
That way it will pulse when using the key fob
------------- If i Can't Install it I Don't need it Joe
Date Posted: December 19, 2017 at 4:51 PM
Thanks for the info. I have completed the install. It seems the the gray/brown in the kick panel was + activation vs all of the - I read. It is working fine now.
