Ignition Switch, Truck w/04 Crown Vic Engine
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144211
Printed Date: May 12, 2026 at 11:39 PM
Topic: Ignition Switch, Truck w/04 Crown Vic Engine
Posted By: manuel76
Subject: Ignition Switch, Truck w/04 Crown Vic Engine
Date Posted: March 05, 2018 at 1:39 PM
Hi, I have an 04 crown vic and I’m trying to swap out the entire engine and trans into a older truck I have, the problem I have is that I want the truck switch to work on the crown vic wiring.. I know the car doesn’t have pats it’s an old cop car all I need is to figure out which wires I need to to make the engine run.. there’s about 6 or 7 hot wires I know some run to the gauges and such.. all I need is the run wires.. thanks in advance.
Always learning
