2013 Ford Explorer Db3/thfd1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144246
Printed Date: May 12, 2026 at 12:01 PM
Topic: 2013 Ford Explorer Db3/thfd1
Posted By: yeeyeebronco
Subject: 2013 Ford Explorer Db3/thfd1
Date Posted: March 20, 2018 at 2:35 PM
Hey y’all, im working on a 2013 Ford Explorer xlt (sa)
I installed a db3 with the thfd1 t-harness. I also have a xkloader3. The firmware installed on the db3 is 3.18. The truck is failing remote start so to the hood pin. Now it is reading the hood pin through the can. At first I thought it was a faulty so I tried starting the truck with hood open and closed, up plugged it and simulated the same with a piece of solder. In the db3 instruction book it says that if hood pin is read through the can, it will fail RS and flash the lights 7 times.
I used the d2d function on the xk3 and can trigger the lift gate the lights locks everything except the RS.
If anyone has any work arounds that would be great. I don’t have access to Directechs anymore otherwise I would call and ask myself.
Thanks in advance.
Date Posted: March 27, 2018 at 11:57 AM
Bad hood pin switch was replaced and it fixed it. Mod please delete
