2015 Toyota Highlander LE Plus Lock And Unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144326
Printed Date: May 12, 2026 at 7:19 AM
Topic: 2015 Toyota Highlander LE Plus Lock And Unlock
Posted By: luminator@2018
Subject: 2015 Toyota Highlander LE Plus Lock And Unlock
Date Posted: April 17, 2018 at 8:20 PM
Hello,
I try to install the Smart Key PKE Car Alarm System to my 2015 Toyota highlander LE plus. I did search and found almost the wires need to connect to PKE Car Alarm system. However, there’re only 2 wires I could not find. That are lock and unlock wires.
I opened the lock/unlock switch on the driver side door and used the multimeter to check the voltage. I found two wires that the voltage change when press lock or unlock switch. But the problem is that when press Unlock, the voltage change from 11.57 VDC to 7.6 VDC (approximately) then after a few second the voltage go back to 11.57. it dose the same when I press Lock (I performed this check on the same wire). It dose the same when I test the other wire. So, I don’t know which one is lock or unlock wire.
If someone knows the lock/unlock wires or wiring diagram of 2015 Toyota highlander LE plus, please share with me. Thank you very much.
Posted By: kreg357
Date Posted: April 18, 2018 at 6:14 AM
Going into the door for the locks can be problematic with the weather-proof door boot, etc. Most
typical installs use a data style bypass module that handles the locks and alarms for you but here
is some info on where you can get the power locks from inside the vehicle at the ECU / Fuse Box.
Omega
Lock        RED (-)           BACK OF DASH FUSE BOX WHITE 32 PIN CONN, PIN 22 *
Unlock     WHITE (-)        BACK OF DASH FUSE BOX WHITE 32 PIN CONN, PIN 27 *
* Test from passenger door switch.
Bulldog Security
POWER LOCK            PURPLE(-) (driver door key lock)@ Body ECU on dash fuse box, white 30 pin plug, pin 29
POWER UNLOCK        LT BLUE DOUBLE PULSE (-) (driver door key unlock)   @ Body ECU on dash fuse box, white 30 pin plug, pin 2
You would need to set the PKE unit for a double Unlock Ouput to unlock all the door at once.
Date Posted: April 18, 2018 at 3:13 PM
I'll try that. Thank you so much for your help.
Date Posted: April 22, 2018 at 9:53 AM
I got it. It's working now. Thank you so much, Kreg357.
Posted By: kreg357
Date Posted: April 22, 2018 at 11:18 AM
Good news. Thanks for the update.
