Do I Need Window Relays 5706V & 535T?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144344
Printed Date: May 12, 2026 at 1:02 PM
Topic: Do I Need Window Relays 5706V & 535T?
Posted By: sandy lrd
Subject: Do I Need Window Relays 5706V & 535T?
Date Posted: April 24, 2018 at 8:53 PM
Hi Guys,
I am converting a manual window to electric powered. The window uses a manual scissors type mechanism and the electric conversion kit consists of the same design. It is not a big window and fairly resistance free, no tight rubber seals. I have not installed it as yet so have not tested the current draw on the initial power load. I will be installing a Viper 5706 and a Directed 535T, do you guys think its advisable to use relays still for the windows or the 535T internal electronics be capable of powering the windows long term with no issues?
I dont know what the internal design is regarding the 535T, do you guys know if it just does a by pass when the switch is used or does it go though the system too as a trigger activation would?
Thanks so much guys.
Cheers.
Date Posted: April 24, 2018 at 8:54 PM
BTW its a 1997 Land Rover Defender 2.5 Turbo Diesel.
Cheers.
Posted By: eguru
Date Posted: April 25, 2018 at 9:21 AM
The 535T supplies current to drive the window motors. It is to be fused for 20A so additional relays are not required.
Date Posted: April 25, 2018 at 9:27 AM
Thanks for the reply and confirmation about the relays.
Cheers.
Date Posted: April 25, 2018 at 9:30 AM
Looking at the 535Ts harness, it does have a 20A inline fuse, I still have to run it from my aux fuse box having another 20 amp fuse anyway.
Thanks again for the reply.
