Electric Life Alarm Won’t Shut Off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144418
Printed Date: May 12, 2026 at 11:09 PM
Topic: Electric Life Alarm Won’t Shut Off
Posted By: bryanmartin
Subject: Electric Life Alarm Won’t Shut Off
Date Posted: May 03, 2018 at 10:22 AM
Hi all. I've installed an Electric Life remote keyless entry and alarm system in my 1978 F250 custom build. I broke the motor in a little while ago and everything went fine, so I have powered it up before with the system installed. I'm completing the end of my build, so I went to reattach the battery cables to check all the electrical systems, and the alarm system triggers every time I go to connect the battery cables. There appears to be no way of turning the alarm off, other than to disconnect the battery cable. The remote controls for the alarm system don't work, as they have not been programmed to the system yet. The problem is, I can't pair them to the system with the alarm activated. The valet switch also does nothing. Does anyone have any experience with the systems? Is there any way to reset it so that it doesn't activate when powered up? Their tech support line has been absolutely no help. I have part number 95125, which includes alarm system part number 95430. I could really use your guys expertise, thanks!
Posted By: mgoetz74
Date Posted: May 03, 2018 at 12:29 PM
I have never heard of that brand before but most alarms can be bypassed by turning the ignition on and pressing the valet button 2 times and holding it on the second press. I hope that helps out some
Posted By: i am an idiot
Date Posted: May 03, 2018 at 12:31 PM
Have you tried turning the key to the run position before you connect the battery? Did you have the key in the on position when using the valet switch?
Posted By: davep.
Date Posted: May 03, 2018 at 3:41 PM
At least unplug the horn or siren so you don't annoy the neighbors (or yourself) while you figure it out. Use the park light flash to monitor system status. Also check your remote(s) battery status. Maybe they're dead after sitting while you built the truck.
