Have to Unlock Before Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144597
Printed Date: May 12, 2026 at 3:07 PM
Topic: Have to Unlock Before Remote Start
Posted By: minhbach
Subject: Have to Unlock Before Remote Start
Date Posted: July 14, 2018 at 2:04 PM
I need some help as I tried to install the Viper 5901 with DBALL3 on the Rave 4 2016 H key.
I have to unlock the car before remote start or I can't unlock or lock the vehicle. Please help
Posted By: geepherder
Date Posted: July 14, 2018 at 2:22 PM
You might try connecting the factory disarm wire, and programming it to pulse when remote started.
Posted By: minhbach
Date Posted: July 14, 2018 at 4:34 PM
To update on the issue. I tried what you have said and it didn't work either. When you said to program it to pulse is that 1 pulse or 2 pulse menu 2 option 8 per 5901 installaton manual.
This DBALL 3 don't even take over the brake and parking light and factory alarm I believe. It only make it be able to start. I have to manually connected the parking light, door trigger, brake wire which is not required per DBALL wiring diagram.
What data wire to setup to these connections on the DBALL3. Please help.
Date Posted: July 15, 2018 at 10:36 AM
I responded to your PM
Posted By: silvercivicsir
Date Posted: July 17, 2018 at 10:47 AM
turn on safe lock in the DBall 3
