2003 Chevy Cavilar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14464
Printed Date: March 18, 2026 at 5:30 AM
Topic: 2003 Chevy Cavilar
Posted By: cool_greg
Subject: 2003 Chevy Cavilar
Date Posted: June 04, 2003 at 4:57 PM
any one got a remote start/alarm diagram wiring listing and I guessing it uses passlock III?
Just a Guy, Wiring up those Vehicals
Gool_Greg
Posted By: JWorm
Date Posted: June 04, 2003 at 11:10 PM
As far as I know, its still passlock 2 and the same as an 02 for wiring. BTW, it would be called Passkey III if it does have the newer system and the shaft of the key would say "PK3"
Posted By: the12volt
Date Posted: June 06, 2003 at 2:21 PM
Yes, the 2003 is the same as the 2002.
Chevrolet
Cavalier
2000-2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW (+)
IGNITION SWITCH HARNESS
Ignition  #1:
PINK (+)
IGNITION SWITCH HARNESS*
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
ORANGE (+)
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
PURPLE / WHITE
ENGINE HARNESS NEXT TO THE BATTERY BELOW THE RADIATOR HOSE
Parking Lights:
BROWN (+)
AT REAR OF LIGHT SWITCH OR DRIVER KICK PANEL
Headlights:
OEM Alarm  Disarm:
DISARMS WHEN VEHICLE IS
STARTED EITHER BY THE KEY OR REMOTELY
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 *This vehicle is equipped with GM's PASSLOCK II Anti-Theft system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
Chevrolet
Cavalier
2000-2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
Starter  Kill:
YELLOW (+)
Ignition  +12 Volts:
PINK (+)
Dome  Lights/Superv:
L GRN/BLK & L BLUE (-)
AT BCM UNDER LEFT SIDE OF DASH ***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
LT. BLUE
Power  Unlock:
WHITE
Trunk  Release:
BLACK/ WHITE (+)
AT BCM UNDER LEFT SIDE OF DASH****
Alarm  Input Wire:
Notes:
** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram. *** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. *** * Use BLACK/ White for 2003 models.
posted_image the12volt • Support the12volt.com
