Avital 4105, 2017 Toyota Rav4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144869
Printed Date: May 13, 2026 at 9:03 PM
Topic: Avital 4105, 2017 Toyota Rav4
Posted By: ricardoboston
Subject: Avital 4105, 2017 Toyota Rav4
Date Posted: October 17, 2018 at 6:37 PM
hello there here its something that its been happening with me on a bunch cars special Toyota, I have installed remote start avital 4105 along with dball3 everything its just fine start ok locks ok but when I lock the doors using the avital remotes I hear like OEM sound exactly as the OEM KEY does ,1 time its ok till there them when I unlock I hear double pulse on the doors its ok but the car makes the OEM SOUND 2 times. one after the other very quickly its kind weird right maybe I should change some of those options on D2D DBALL?
Posted By: eguru
Date Posted: October 18, 2018 at 7:52 AM
So, you are installer and have had problems on multiple installs?
What do you mean by "OEM SOUND"?
Posted By: iskidoo
Date Posted: October 18, 2018 at 9:43 AM
I think the vehicle needs the double pulse to disarm the factory security. You should probably leave it as is if everything is working. Many aftermarket systems beep once when armed and twice when disarmed. Maybe others will chime in if they know of a different way to configure the settings.
------------- Steve G
Posted By: silvercivicsir
Date Posted: October 19, 2018 at 2:03 PM
Oem chirp is normal, you can turn it off if you no likely in the dball3 menu
Date Posted: October 19, 2018 at 6:50 PM
can you guys tell me with opitions on dball3 should be change thanks
