2006 Chevy Trailblazer Remote Start Dies Immediately
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144879
Printed Date: May 14, 2026 at 4:26 AM
Topic: 2006 Chevy Trailblazer Remote Start Dies Immediately
Posted By: spadz93
Subject: 2006 Chevy Trailblazer Remote Start Dies Immediately
Date Posted: October 20, 2018 at 5:35 PM
I had a viper 4806v with a flashlogic flcan installed in my 06 trailblazer and it was working just fine except it wouldn't unlock with the fob all the time, so I switched from data connection to hardwired mode and now the car will start but die immediately when using remote start. Tried relearning the tach to see if that helped any, but it didn't. When the car dies, the anti-theft light on the dash flashes three times. The remote start doesn't seem to see that the car shut off (it's a two way kit, and no error message is sent back to the remote when the car dies). Any ideas? I'm about to order a fortin evo-all, had great luck with it on my other car but figured i'd give the flcan a try.
Posted By: geepherder
Date Posted: October 20, 2018 at 6:49 PM
Hopefully someone will correct me if I'm wrong. If you want to hardwire the locks, just connect directly from the alarm to the car. I think you need to stay in data mode to handle the immobilizer.
------------- My ex once told me I have a perfect face for radio.
Posted By: len barron
Date Posted: October 21, 2018 at 7:27 AM
Probably need to connect the 24 Pin connector Pin 5 DARK BLUE (-) 200mA STATUS OUTPUT to the bypass module so that it knows the run status.
------------- Len
2000 Express Hightop Duramax Allison 4x4
