2003 Chevrotet S-10 starter disable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14491
Printed Date: March 17, 2026 at 8:35 PM
Topic: 2003 Chevrotet S-10 starter disable
Posted By: skyace4
Subject: 2003 Chevrotet S-10 starter disable
Date Posted: June 05, 2003 at 1:32 AM
I have a 2003 Chevy S-10 that is getting a new Commando RS-560 Alarm system put in it with a starter kill relay and I need to know what are the correct wires to use under the steering column for the relay, I am also needing to know where the tach. pickup wire is to be tapped and what color it is.
The Chevy dealer mechanic said I will find the PCM module near the battery on the passenger side and not to touch any modules that have a yellow connector on them since these modules are for the air bag system.
I could use the help, seems Commando Car alarms does not keep up on the vehicles and the schematics.
I also noticed the kit does not have a hood pop-up switch to install for the remote starter that came with the kit.
Thanks.
John.
skyace4@hotmail.com
Posted By: draasch
Date Posted: June 06, 2003 at 9:17 PM
this is for the 02. double check with a meter
Starter YELLOW OR PURPLE IGNITION SWITCH HARNESS
Tach Signal WHITE AT IGNITION CONTROL MODULE
* Ignition Control Module Is Located On The Passenger Side Of The Engine Compartment.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: DeathsJester12V
Date Posted: June 07, 2003 at 4:42 AM
12volts          red       +     ignition   harness
Starter          yellow    +       ignition harness
Ignition        pink         +         ignition harness
Power Lock       lt. blue +         brown plug at BCM         *1
Power Unlock     white         +         brown plug at BCM         *1
Lock Motor       gray        5wi        driver kick panel
Unlock Motor     tan        5wi        driver kick panel
Disarm Defeat    tan        5wi        passenger kick panel
Parking Lights+ brown         +         lt. blue plug at BCM    *1
Parking Lights- white         -         lt. blue plug at BCM    *2
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger               -           purple plug at BCM    *3
Dome Supervision               use door trigger
Trunk/Hatch Pin           N/A
Hood Pin
Trunk/Hatch Release       N/A
Power Sliding Door       N/A
Factory Alarm Arm
Factory Alarm Disarm lt. green - purple plug at BCM     *1
Disarm No Unlock    see factory alarm disarm
Tachometer     white       ac       PCM                         *4
Horn Trigger   black       -       steering column         *5
*1 The BCM (Body Control Module) is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the driver side.
*2 This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground.
*3   Use tan for the driver door located in pin B4, orange for the passenger door located in pin B2. Use both wires and diode isolate.
*4   The PCM (Powertrain Control Module) is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20.
*5   Also found in the brown plug at the BCM on vehicles with a factory alarm.
Hope that helps a bit...sorry the notes got messed up...but what can I do...
And yes this is for a 2003 s-10
