2017 Jeep Renegade, Heater Fan Not Blowing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145009
Printed Date: May 15, 2026 at 5:30 AM
Topic: 2017 Jeep Renegade, Heater Fan Not Blowing
Posted By: ricardoboston
Subject: 2017 Jeep Renegade, Heater Fan Not Blowing
Date Posted: December 04, 2018 at 7:28 PM
please I really appreciate if you great tech help me with this remote start installation I have done a remote start avital 4105 D2D along with ads al ca on the 2017 jeep renegade ,everything works just fine almost perfect. my problem its on the car start it up with the remote start it won't blow air no even the heater works car start up ok but not the blower nothing comes out of the vent ?if any of you would give me a tip what to do on this case thanks a lot
Posted By: geepherder
Date Posted: December 04, 2018 at 11:21 PM
If I understand you correctly, your a/c control panel comes on, but not the blower.
Bookmark this page that Ween posted:
https://www.bbbind.com/free-tsb
Select wiring diagrams, vehicle, etc... HVAC controls
https://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=1193703
Scroll down to page 5.
Remote start your vehicle and check with your meter to see if the blower motor power module is getting power. If it isn't, check the grey/white wire that feeds the blower motor relay. You can try to connect that to an unused ignition feed from the remote start and see if that fixes the issue.
Date Posted: December 05, 2018 at 9:36 PM
Thanks a lot I will do it exactly as you said let you know soon
