2005 Sebring Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145061
Printed Date: May 15, 2026 at 10:07 AM
Topic: 2005 Sebring Remote Start
Posted By: Team montecarlo
Subject: 2005 Sebring Remote Start
Date Posted: December 16, 2018 at 9:22 PM
Hi guys. I have a Viliant RS-160 from IC Dynamics (given to me) I am wanting to install in my daughters Sebring convertible. I am not a pro, but also am not new to remote start installs (did 2 of my ZJ jeeps and a 99 Grand Am years ago). I just have a couple of questions.
First off, the car has a transponder key that was placed in the column so regular keys work to start it. I assume, but not positive, that I won't need a bypass module and can just connect the RS like I would with no security(i.e. like my ZJ) if I just leave the key there. Or do I need to but a bypass module that I can program with just one key?
Second, for the life of me I can't find a diagram for the single trigger door locks. I know it uses resistors, 1780 to lock and 730 to unlock (or there abouts depending on what source you get the info from), and will need relays but I can't find an actual diagram. I know the ZJ's were a real PITA, with 2 relays in each door. Is the Sebring going to be a similar pain? Or would it just be better in the long run to but a bypass that can control the locks and kill two problems at once.
I don't mind the challenge of getting it to work without a bypass if it is possible, except I just may be getting too old to be laying on the floor for that long.
Any info would be greatly appreciated. Thanks.
EDIT: I believe I figured out my lock dilemma. I believe it is as easy as using the diagram for Converting a Negative Trigger to Positive Output Diagram in the Relay Diagrams forum, then basically following the Dodge Caravan Type H wiring diagram with the resistors between the relay output and the door circuit (positive trigger instead of negative obviously). How close does the resistance have to be? I have seen multiple values listed (at least 4 different ratings between 1.6k to 1.8k and 680 to 820) while searching this. Do I just need to be close or can I use a couple of potentiometers and fine tune it? I have a project box and a perf test board lying around I can whip up the circuit pretty quick I believe.
Posted By: geepherder
Date Posted: December 16, 2018 at 9:46 PM
If it's working now with the key in column, it's bypassed permanently (easier to steal), but it'll work.
Bulldog has a diagram:
https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
https://diagrams.marktoonen.nl/printlist.aspx?MakeID=14&ModelID=19721
https://diagrams.marktoonen.nl/DOWNLOADS/14301_SEBRING-CONVERTIBLE_CHRYSLER%20COUPE%20and%20SEDAN%201%20WIRE%20JBS%20UNITS.pdf
Door locks look simple enough, just a positive trigger through a resistor, not multiple relays in each door.
------------- My ex once told me I have a perfect face for radio.
Date Posted: December 16, 2018 at 10:05 PM
Thanks geepherder. I must have been editing when you posted. Thanks for the bulldog tip. That was where I found the lock diagram for the ZJ and was racking my brain trying to remember what site I got it from. The RS only has negative lock triggers so I will have to use relays to go to positive. Appreciate the help.
