Avital 5305l Install, 2010 Lincoln MKZ
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145096
Printed Date: April 24, 2026 at 8:03 PM
Topic: Avital 5305l Install, 2010 Lincoln MKZ
Posted By: andyvillen
Subject: Avital 5305l Install, 2010 Lincoln MKZ
Date Posted: December 23, 2018 at 11:52 PM
Hey all,
I installed a avital 5305l on my 10 lincoln MKZ along with a fortin key-bypass-sl2.
The car will not crank on remote. But if I power the starter wire when it should be cranking it starts and runs.
Is there something I'm missing?
I followed the pictorial on here, the remote has a security but I didnt hook any of that up. Does the remote need to see something from that to start?
Thanks Andy
Posted By: chev104275
Date Posted: December 24, 2018 at 6:21 AM
Can you list out what you did connect ? So we can get a better idea of what's going on.
------------- If i Can't Install it I Don't need it Joe
Date Posted: December 24, 2018 at 7:53 AM
For sure,
Main 5 pin harness chassis ground, fused 12v constant, parking light output.
Remote 10 pin harness fused 12v ignition 1 relay input, starter output , accessory output, ignition 1 input/ output.
24 pin harness
Trunk release output, hood pin input, horn honk output( does not honk horn ), brake shutdown input.
Thanks in advance :)
Posted By: geepherder
Date Posted: December 24, 2018 at 8:21 AM
It looks like you didn't connect the power wire (red/black) for the starter. I always connect all three red fused wires in the remote start harness.
------------- My ex once told me I have a perfect face for radio.
Date Posted: December 24, 2018 at 9:04 AM
do you put the red/black with the violet ?
OOOOOHHHH, i understand now... haha... CLICK!
Date Posted: December 24, 2018 at 9:17 AM
That was my problem ! thanks for the help!
