Horn Honk, Avital 4105, 2016 Toyota Rav4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145234
Printed Date: April 27, 2026 at 6:21 PM
Topic: Horn Honk, Avital 4105, 2016 Toyota Rav4
Posted By: ricardoboston
Subject: Horn Honk, Avital 4105, 2016 Toyota Rav4
Date Posted: February 12, 2019 at 4:00 PM
hi there I got a problem that I need to figure out how to activate the horn on 2016 Toyota RAV4 using Avital 4105 I need it to sound at least one time when the remote start is activated because I need to know if the car got the signal from the remote, any help really appreciate
Posted By: guerra_85
Date Posted: February 12, 2019 at 4:15 PM
Which one is it???
------------- Guerra_85
Date Posted: February 12, 2019 at 4:18 PM
Smart key, Hybrid o regular???
Posted By: motosaki
Date Posted: February 12, 2019 at 4:23 PM
You should be able to program an aux wire for arm or lock after start and wire a relay to the horn wire I would think.
------------- 15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
Posted By: silvercivicsir
Date Posted: February 13, 2019 at 4:47 PM
can't you just look to see if the "park lights" are on? if you can't see the park lights, I doubt you will hear the horn honk.
Date Posted: February 14, 2019 at 5:16 PM
guerra_85 its a regular one thanks
Date Posted: February 14, 2019 at 5:34 PM
I was thinking to use the factory alarm disarm on the horn wire I think it will work cause that wire will pulse negative signal before the car starts up ,what you guys think thanks
Date Posted: February 15, 2019 at 12:12 AM
Posted By: iskidoo
Date Posted: February 15, 2019 at 10:05 PM
Should work. I’d use some alligator clips to temporarily connect the relay to insure it behaves the way you want it to before connecting it all up for good. Seems like you are on the right track. ------------- Steve G
