2009 Buick Lucerne Remote Start Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145396
Printed Date: May 12, 2026 at 1:21 AM
Topic: 2009 Buick Lucerne Remote Start Install
Posted By: jagnew
Subject: 2009 Buick Lucerne Remote Start Install
Date Posted: May 04, 2019 at 11:16 PM
I am doing an remote start install on an 09 lucerne. The wiring dosen't have heavy gauge wires at ignition. I'm installing avital 4105i remote start with xpresskit bypass. All of the diagrams and reference guides are no help any ideas on wireing?
------------- Jagnew
Posted By: geepherder
Date Posted: May 05, 2019 at 6:32 AM
I'm assuming you looked here in the vehicle wiring section.
https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx is a useful resource for wiring information.
Also, Xpresskit is not a specific bypass, but a product line under Directed.
You maybe able to lookup a guide for your specific bypass here: https://old.directechs.com/VehicleCompatibility.aspx?p=-1&v=3227&ps=1&s=0&c=0&pr=-1
Different bypass companies, but you can sometimes lookup a bypass module to find wiring info here also:
https://fortin.ca/en/vehicles/buick/lucerne/2009-standard-key/
https://www.idatalink.com/search/search?vehicle_make_id=5&vehicle_year_id=2009&vehicle_model_id=576&vehicle_id=5897------------- My ex once told me I have a perfect face for radio.
Posted By: jagnew
Date Posted: May 18, 2019 at 2:33 PM
I finally had time to work on it still no success.
Date Posted: May 18, 2019 at 5:56 PM
We need more information to help you. Specifically, what bypass are you using? Has it been successfully flashed? What connections have you made (factory color/pin location to aftermarket color/pin location/harness)?
What does no success mean? What is the exact issue you have? Does the ignition power but no crank? Does it crank but never start?
Posted By: jagnew
Date Posted: May 19, 2019 at 10:04 PM
The bypass is pkmux i have all connections per install made. The ignition powers but no crank. Thank you for your help.
Posted By: kreg357
Date Posted: May 20, 2019 at 6:58 AM
PKMUX? Don't remember that bypass module. The closest one I cam find is the PKUMUX
and that one only covered the Buick Lucerne until 2006, not your 2009 model.
------------- Soldering is fun!
Date Posted: May 20, 2019 at 5:43 PM
Yes, it's likely the PKUMUX. It's actually listed for 2006-2009 Lucerne.
Is this the guide you used?
https://directechs.blob.core.windows.net/documents/pkumux_en_ig_cp20110630a.pdf
Place a key in the ignition without turning and try to remote start.
If that works, the problem is with the bypass (wiring, programming, faulty unit, etc.). ------------- My ex once told me I have a perfect face for radio.
Posted By: jagnew
Date Posted: May 22, 2019 at 8:03 PM
Yes sorry pkumuk. Even with the key in it wouldn't crank so i may not have programmed bypass correctly is what i am guessing.
Date Posted: May 22, 2019 at 8:52 PM
I somehow missed that part.
Do you have the red/black wire in the remote start harness connected to constant power? Is the fuse good? Is there any voltage on the purple wire during remote start (when it should be cranking)? ------------- My ex once told me I have a perfect face for radio.
Posted By: jagnew
Date Posted: June 01, 2019 at 9:39 PM
Sorry took so long to get back. Ended up a bad bypass all is good and works great
