Aftermarket Door Lock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145472
Printed Date: April 15, 2026 at 12:54 AM
Topic: Aftermarket Door Lock
Posted By: rivraton
Subject: Aftermarket Door Lock
Date Posted: June 15, 2019 at 11:37 PM
I am installing a AVITAL 3100LX on a 2001 Dodge Ram that has an aftermarket central locking kit installed. It has a master lock motor on the Dr. side, and I need Neg. pulse to lock / unlock It looked to be easy...
(From the installation Guide):
Door Lock, 3-Pin Connector (H2)
1 GREEN (-) Lock, (+) unlock output
2 OPEN except if using 451M
3 BLUE (+) Lock, (-) unlock output
I thought a diode on each of the lock control wires (per attached image) should give neg. pulse to each wire... but I must be missing something because that didn't work.
Any suggestions?
posted_image
Posted By: i am an idiot
Date Posted: June 16, 2019 at 6:11 AM
Use a meter to verify it grounds when you press the switch to lock or unlock. If it does, eliminate the diodes.
Posted By: catback
Date Posted: June 16, 2019 at 8:49 AM
Is that the actual layout of the central locking kit? A separated actuator, controller, switch setup? What aftermarket central locking kit is it?
Posted By: rivraton
Date Posted: June 16, 2019 at 11:56 AM
Unbranded but identical to Lanbo. Here is the full layout (I'm tying into the white and brown leads (5 &6)) posted_image
Posted By: catback
Date Posted: June 16, 2019 at 4:10 PM
Do pin 5 and 6 work as you expect? Ground 5 or 6 and the locks lock or unlock? If so and they don't work directly connected to the avital then a 451m or a pair of relays are going to be needed as the Avital output can only handle 500mA of current.
Posted By: rivraton
Date Posted: June 16, 2019 at 4:29 PM
OK, thanks for the help... I'll order a module...
ETA: It looks like I'll have to use a set of relays, a 451m will give me Pos. pulses...
Posted By: catback
Date Posted: June 16, 2019 at 7:03 PM
A 451m can be configured a variety of ways with pos or neg output
Date Posted: June 17, 2019 at 9:13 AM
Pretty sure you do not need a module. It looks like that keyless entry module is designed to use in conjunction with your alarm.
Posted By: rivraton
Date Posted: June 17, 2019 at 2:26 PM
It looks like it should...but it doesn't...
Date Posted: June 17, 2019 at 5:42 PM
Without the diodes?
Posted By: rivraton
Date Posted: June 17, 2019 at 6:14 PM
i am an idiot wrote:
Without the diodes?
Tried it both ways, it does not work... If it is supposed to, as you seem to be certain, then I must have a defective alarm controller... I won't condemn it until I try the 451m
Posted By: rivraton
Date Posted: June 20, 2019 at 4:27 PM
I just dropped back to update on this... I got a 451m and wired it for neg pulses and it works :^: One side note if you need to go this route, insulate or isolate the white/black and brown/black leads at the outset... If they make contact, it will reverse the lock / unlock signals :oops: This was happening intermittently when the harness was moved
Thanks to all for the guidance.
