Crimestopper CS2011RS, 2002 Toyota Corolla
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1455
Printed Date: April 18, 2026 at 9:44 PM
Topic: Crimestopper CS2011RS, 2002 Toyota Corolla
Posted By: mike08401
Subject: Crimestopper CS2011RS, 2002 Toyota Corolla
Date Posted: June 23, 2002 at 8:55 PM
I just installed an alarm+autostart( Crimestopper cs2011rs) to my 2002 ToYoTa Corolla. It seem to be OK but I have 2 problem and need your Master mind help.....When start with the remote the engine take too long to start normal I mean It cranking too long before it running normal compair to the other car I have. And other problem is i can't find where is the wire of door switch not the door lock/unlock because when i pull the door latch manually the alarm is not function. thank for your advice
   Dummyposted_image
Posted By: Velocity Motors
Date Posted: June 23, 2002 at 10:13 PM
Make sure you have the proper tach wire for the Corolla and if you are using the tachless feature, change it and connect the tach input wire on the CS to the YELLOW /GREEN or the RED / BLUE wire at the ignition coil. Below is the color codes for the doors and what not sopost your results:
Toyota
Corolla
1998-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
IGNITION SWITCH HARNESS
Starter  Kill:
RED
Ignition  +12 Volts:
BLACK/ WHITE
Dome  Lights/Superv:
RED / WHITE (-)
AT INSTRUMENT CLUSTER OR AT FUSE BOX *
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
BLUE/BLACK (-)
RIGHT SIDE OF FUSE BOX IN A WHITE PLUG
Power  Unlock:
GREEN / WHITE (-)
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE (-)
Notes:
* There Are Mulitple RED / White Wires Near The Fuse Box. Some Will Work Individual Doors Only. Test With A Meter To Identify The Single Wire That Reacts To All Doors.
