Viper 5305V, 1996 Crown Victoria
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145528
Printed Date: April 27, 2026 at 3:55 AM
Topic: Viper 5305V, 1996 Crown Victoria
Posted By: jim2467
Subject: Viper 5305V, 1996 Crown Victoria
Date Posted: July 21, 2019 at 1:39 PM
I am having a problem with my wiring on my 1996 Crown Victoria. I am installing a Viper 5305V remote start, keyless entry & alarm. I have the keyless entry and alarm working just fine. It is the remote start that is giving me trouble. When I press the remote start on the 2 way LCD remote the brain box for the system just makes some clicking noises and then doesn't even try to start after that. I have all the wires connected and I have started my car with the key and let the system learn the tach signal. My Crown Victoria has 2 coil packs and I am getting my tach signal from the one on the driver's side. Is that correct or should I get it from the other one on the passenger side near the battery. I have programmed the 2 way LCD remote and the 1 way remote. I went through and set up all three menus. I get 5 flashes on the control LED which says there is an issue concerning the pink/white wire for the starter. I have checked and rechecked my wiring to insure the connections are correct and have a solid connection. I am stumped and could really use some help at this point. Any suggestions would be greatly appreciated at this time!!!!!
Thanks,
Jimmy Gregory
Posted By: iskidoo
Date Posted: July 21, 2019 at 5:35 PM
Did you wire up a hood pin? If not then the hood pin wire needs to be grounded in order to remote start.
Steve G
Posted By: geepherder
Date Posted: July 22, 2019 at 6:20 AM
As Steve mentioned, 5 flashes is the hood input.
If this wire is grounded it will not start. Temporarily disconnect this wire and try again.
