Black Widow Alarm Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14553
Printed Date: March 16, 2026 at 3:59 PM
Topic: Black Widow Alarm Problem
Posted By: cbowery76
Subject: Black Widow Alarm Problem
Date Posted: June 06, 2003 at 7:56 PM
I recently installed a Black Widow Keyless Upgrade kit in a 2k2 Nissan Sentra.  The alarm works fine except that on occasion it will arm itself when turning the ignition from run to off.  This is very annoying as you would guess.  It also dosen't seem to arm unless I close all doors and wait a few seconds.  Any thoughts?
Posted By: draasch
Date Posted: June 06, 2003 at 9:33 PM
make sure you have this wire hooked up the alarm switched ign wire.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: robHI
Date Posted: June 07, 2003 at 2:32 AM
did u put in diodes?
Date Posted: June 09, 2003 at 5:41 AM
I'm pretty sure it's hooked up correctly.  I can double check.  I didn't use diodes however, I wasn't aware that you needed them on the ignition wire.  If so, please let me know.
Posted By: BulletTooth
Date Posted: June 09, 2003 at 10:43 AM
This is a self arimng feature that if you don't like you could disable by reprogramming. Check your owners/install manual it tells you how to do it, if not just give me the model and I'll let you know
Date Posted: June 09, 2003 at 4:01 PM
I don't think it's the self arming feature since I have that disabled and it's not supposed to arm until 30 seconds after circuits have been closed.  It arms itself from the turn of the ignition to off.  It only does it every 10 times or so.  Do I need a diode?  I'm lost.
