1991 Toyota 4Runner, 5 Speed, Remote Start Issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145549
Printed Date: May 15, 2026 at 9:56 AM
Topic: 1991 Toyota 4Runner, 5 Speed, Remote Start Issues
Posted By: whitleyca
Subject: 1991 Toyota 4Runner, 5 Speed, Remote Start Issues
Date Posted: July 31, 2019 at 10:57 AM
I would like some help in wiring the clutch switch into the starter relay provided with the compustar cm7000 system.
I know the black/red (+) and white/black (-) are the two wires for the clutch switch, but I don't know where there respective locations should be on the relay circuit. It appears the circuit is normally open as well.
Please find the wiring for the 4runner start system below.
https://www.teamtoyota4x4.org/archivio/1990-1995_4runner_wm/techinfo.toyota.com/ileaf/toyewdvf/toyewpdf/vfewdsou/1995/954runne/systemci/start.pdf
Posted By: iskidoo
Date Posted: July 31, 2019 at 6:06 PM
Date Posted: August 02, 2019 at 11:02 AM
thank you for the diagrams. Please talk me through this. I tried the first relay link (normally open) before I posted on the forum. It let the smoke out of a wire, now the flasher relay continuously clicks. The doors are negatively triggered, so I should use the negative output wiring on the second page of the second link?
I'm thinking that I powered the ground wire and fried the flasher relay, because it will click as soon as it receives accessory power.
Thanks,
Chad
Posted By: iskidoo
Date Posted: August 03, 2019 at 5:26 AM
I think you’d better read this post and properly test which system you have before you connect anymore wires. I’m not sure what the door triggers have to do with your clutch bypass setup, so I’m not sure what you are talking about. Please test with a DMM before hooking up any more wires.
https://www.the12volt.com/installbay/forum_posts.asp?tid=70817
Steve G
Date Posted: August 23, 2019 at 11:55 PM
posted_image
Okay, so I found out I have a negative triggered clutch switch. How can I integrate it into the relay in the picture I attached? I tried the diagrams provided, but it doesn’t run to ground, and I need the current figuration to get the vehicle to start.
