2000 Toyota Celica, Manual Transmission, Clutch Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145701
Printed Date: May 13, 2026 at 10:21 AM
Topic: 2000 Toyota Celica, Manual Transmission, Clutch Wire
Posted By: sand33p_sidhu
Subject: 2000 Toyota Celica, Manual Transmission, Clutch Wire
Date Posted: October 22, 2019 at 9:58 AM
Hello,
I am installing a remote start in 2000 Toyota Celica Manual Transmission. I have completed the install but i am unsure of clutch wire to bypass with remote start. Any idea what wire i should connect on the vehicle and if it is positive or negative?
I have used CompuStar FT7200 module, no bypass since vehicle doesn't have mobilizer.
Please advise.
Thank You in advance.
Posted By: kylehondarider
Date Posted: October 22, 2019 at 10:31 AM
Find the switch at the top of the clutch pedal and splice in each wire from the switch to pins 87 and 30 of a relay. Connect 86 to negative and 85 to your remote start's starter wire.
Date Posted: October 22, 2019 at 10:33 AM
Better would be 85 to positive and 86 to a negative signal starter wire from your R/S that's enabled when starting.
Date Posted: October 23, 2019 at 3:43 PM
So you mean attached pin 30 & 87 to the each clutch wire? According to what i remember, there is black/orange wire and then there is black yellow wire at the clutch switch. I thought i would give it negative or positive pulse from remote for it to start. Also wondering if i connected the wires together at the clutch switch, it should start the vehicle right, which is basically what we are doing with the relay and i did do that test and it did not start the vehicle.
Just a test that i've done, when i test the wires at the clutch switch, they both measure positive and when i press the clutch, it measures negative on one of the wires.
Posted By: silvercivicsir
Date Posted: October 25, 2019 at 3:13 PM
if i remember correctly.. thin blk off the 7200 for "negative start" to the blk yellow at the clutch.
Date Posted: October 25, 2019 at 8:38 PM
Seems like black yellow is for cruise control. I found black/white & white/black which seems like it's for clutch. When I manually join the 2 wires together it starts without pressing the clutch so I wired in relay to basically join them together and still doesn't start. Not sure what else to do with this thing anymore.
Posted By: geepherder
Date Posted: October 26, 2019 at 4:58 AM
How is your relay wired?
 ------------- My ex once told me I have a perfect face for radio.
Date Posted: October 28, 2019 at 10:41 AM
So i figured it out, apparently just a regular negative start or GWA from remote start is not enough so i had to change the polarity using relay and trigger it with positive start wire from remote start and BOOM! it works! It was actually Black/White wire at the clutch.
Thank You for all the help!
