Compustar CS4900 Issue, 2010 Ford Fusion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145769
Printed Date: May 13, 2026 at 9:03 PM
Topic: Compustar CS4900 Issue, 2010 Ford Fusion
Posted By: tlower
Subject: Compustar CS4900 Issue, 2010 Ford Fusion
Date Posted: November 09, 2019 at 10:59 AM
Just installed a Compustar cs4900 remote start in a 2010 Ford Fusion and I can not get the Blade to read the key (keeps flashing red). I have double and triple checked all the wiring, reset and reprogrammed the module several times. I checked the voltage at the pats power wire and I'm getting 4.97v with the key inserted. I've always seen 0v or 12v nothing in between like this. Any suggestions?
Posted By: eguru
Date Posted: November 10, 2019 at 9:02 AM
Which wire are you referring to as "the pats power wire"? What colour is it?
Posted By: tlower
Date Posted: November 10, 2019 at 9:30 AM
Lt Blue/Black wire
Posted By: eguru
Date Posted: November 10, 2019 at 5:11 PM
IDK what your BU/BK wire is for. There is a BU/GY wire (key sense).
Sorry, I guess I can't help you on this.
