2008 Ford Explorer, Plug and Play Remote Start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145911
Printed Date: May 13, 2026 at 11:14 PM
Topic: 2008 Ford Explorer, Plug and Play Remote Start?
Posted By: relentless85
Subject: 2008 Ford Explorer, Plug and Play Remote Start?
Date Posted: January 04, 2020 at 6:03 PM
Does anyone make a plug and play remote start module for a 2008 Ford Explorer? I have seen one on the internet but is said the vehicle would need a second flash programming? Something to do with a key klon? I’m unsure of what a key klon is? Something to do with a key not needing to be in the vehicle since the keys have a transponder in them?
I am looking for an easy way to add remote start to this vehicle, don’t want to mess something up by needing to splice wires.
Posted By: jvwilson101
Date Posted: January 04, 2020 at 9:36 PM
I did a quick google search and didn't find anything completely plug and play for your vehicle. If you know someone competent in 12V vehicle electronics I would recommend a Fortin Evo-One or Evo-All as these are both solid and reliable units a consumer can flash from home. If not, I would recommend a reputable local shop handle the install for you.
