Viper GWA and Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145968
Printed Date: May 16, 2026 at 1:50 AM
Topic: Viper GWA and Remote Start
Posted By: itolond
Subject: Viper GWA and Remote Start
Date Posted: January 23, 2020 at 6:39 PM
Hi Forum,
I look to 'immobilize' my Diesel 4x4 by putting a 5 pin relay in to isolate the fuel supply solenoid. Looks like this would be the easiest way to achieve such and simple to rig up. But I have some unknown and my logic maybe floored.
The setup would be to supply const DC +to the relay switch and have the Ground when armed complete the route to trigger the relay - therefore isolating the solenoid. when GWA not longer active the relay would simply revert to normal operations.
I am not sure how Remote start impact this - does GWA still operate when the vehicle is in remote start mode? - if so any other options would link to the Viper?
Posted By: geepherder
Date Posted: January 23, 2020 at 7:01 PM
Instead of constant +12 volts going to your relay coil, just use ignition. This will keep the alarm from draining the battery. Once the key is turned to ignition, if the alarm is set, your relay will trigger.
*As you may already know, many folks won't interrupt a wire other than the starter wire for liability reasons (something fails driving down the highway, etc.)*
I have done this before on my own vehicle, but not for others.
------------- My ex once told me I have a perfect face for radio.
Posted By: itolond
Date Posted: January 23, 2020 at 7:04 PM
I was not aware of this approach (starter only) - why?
Posted By: itolond
Date Posted: January 23, 2020 at 7:47 PM
Just thinking - the viper already isolates crank start correct?
Date Posted: January 24, 2020 at 4:14 AM
Because if you interrupt the starter wire the worst thing that can happen is the car not starting. If you interrupt the fuel pump wire and there's a problem, worst case would be the car dying while in motion, causing an accident, etc.
Yes, if you cut the starter wire and connect both the green and purple wires, this will take care of starter kill.
Posted By: itolond
Date Posted: January 24, 2020 at 5:42 AM
gotcha T
he model of 4x4 is notorious for theft (i believe one every 20 mins) high demand vehicle out of production.
I fell the risk is worth is - I will put in place a hidden bypass just in case
Date Posted: January 24, 2020 at 6:00 AM
Something else to consider would be to interrupt a low current carrying relay trigger wire instead of a high current carrying wire that drives the load (fuel pump). This would make it even less likely to burn up the contacts of your relay since the current it'd be switching would be minimal. This is what I did on my fuel pump, using OEM style connections, etc. Even if someone were to find my relay, they may not even know it was added in.
