Long Throw Door Lock Actuator, 1" or More?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146008
Printed Date: May 15, 2026 at 11:50 PM
Topic: Long Throw Door Lock Actuator, 1" or More?
Posted By: gotchaz
Subject: Long Throw Door Lock Actuator, 1" or More?
Date Posted: February 09, 2020 at 7:52 PM
The generic motor driven door lock actuator that is on the after market tailgate lock assembly of my Tundra pickup does not have enough travel (3/4") to consistently lock the tailgate. I can adjust it to either always lock or always unlock the tailgate, but not both.
Are there extended or long throw actuators (1" or more) available?
Posted By: silvercivicsir
Date Posted: February 10, 2020 at 12:04 PM
you could always try moving the actuator?
Posted By: gotchaz
Date Posted: February 10, 2020 at 12:08 PM
Thanks, but I actually need more travel from stop to stop in both directions, not just in one direction
Posted By: geepherder
Date Posted: February 10, 2020 at 2:12 PM
You could try rigging up a lever system.
------------- My ex once told me I have a perfect face for radio.
Posted By: gotchaz
Date Posted: February 10, 2020 at 5:39 PM
I have a Bell Crank idea in mind, but a longer throw generic actuator would make things very simple but they all appear to have 3/4" (20mm) travel.
I did find on someone who had laser print an extended rack to replace the original rack in one of these actuators ( https://www.thingiverse.com/thing:1057723) but that's a little outside of the scope of what I need to do (and I don't have a 3d printer handy!)
Posted By: i am an idiot
Date Posted: February 10, 2020 at 7:15 PM
How much room do you have available? How easy does the mechanism move? You could possibly build a simple lever system with a 1 to 1.5 ratio that would turn the 3/4 inch movement to 1-1/8 or so.
